Can I run two CLI jobs in the same repository at the same time?
Will anything bad happen if I run two instances of the CLI program in the same repository but two different storages at the same time?
I think it should be fine generally, as every storage has its own cache directory and the cache is the only thing a command would write to locally.
I do this, running two instances of the CLI in the same repository and sending it to two storages (dropbox and google drive). No problem.
P.S.: I think the thread category above is wrong … It’s CLI and not GUI, right?
towerbr, yes you are right, I mis-categorized the thread.
And THANK you for your reply. Much appreciated.
