Duplicacy vs Duplicati
There is an interesting discussion comparing Duplicacy with Duplicati: Duplicati 2 vs. Duplicacy 2 - Comparison - Duplicati
Performance wise, Duplicacy is about 2-3 times faster than Duplicati with the default settings (3:09 vs 9:07 for a small data set, and 0:27:27 vs 1:12:40 for a larger one). By disabling compression and encryption, and applying an optimization on the hash function, they were able to achieve the same or even slightly better performance (than Duplicacy with compression and encryption), but the CPU utilization was still significantly higher.
Those tests were done using one thread. Duplicacy already offers the -threads option for multithreaded uploading and downloading, while Duplicati currently doesnā€™t, and it is unclear when it will be available.
Feature wise, Duplicati comes with a web-base UI and is more feature-complete than Duplicacy. It also has a larger number of storage backends. However, Duplicati lacks the killer feature of Duplicacy, cross-client deduplication, and it doesnā€™t look like it will ever support it.
In my opinion, Duplicatiā€™s main problem is the use of the database and the aggressive approach to attempt to ā€˜repairā€™ it (as pointed out by several users in that thread). More than one new Duplicacy users mentioned that the database corruption is the main reason they gave up on Duplicati. Their developer argued that by taking an aggressive repair approach one will be able to identify storage issues sooner. In Duplicacy we took the opposite way ā€“ we assumed that all the cloud storage can be trusted and we based our design on that. In cases where a cloud storage violates this basic assumption (for example, Wasabi, OneDrive, and Hubic), we will work with their developers to fix the issue (unfortunately not everyone is responsive) and in the meantime roll out our own fix/workaround whenever possible.
Having said the above, I applaud their collaborative efforts to start and expand such as discussion. Both sides can learn from each other and have something different to catch up on. A comprehensive and insightful comparison like this will only advance our understanding and make both software better in the long run.
I tried duplicati before I found duplicacy and I could not get it to work easilyā€¦ and the support was not very helpful (unlike duplicacy).
I dont know about the validity of trusting the storage back - end :slight_smile: But we have discussed that before with a possible upcoming feature to help server side verification. Looking forward to that.
@kevinvinv can you submit a github issue for that feature if you havenā€™t done so?
Did it :slight_smile: THanks.
Thanks @gchen, for a fair summary of that comparison thread. Yes, this kind of open discussion is what moves open source software along (and what helps users make informed decisions).
Regarding the approach of trusting the backend, I wonder if anyone can give some indication as to what trusting implies in practice. I suspect that, despite fundamentally different approaches (trusting vs not trusting), in practice, the difference is not so big (because a lot has to go wrong before you actually lose data because you trusted). Or maybe it is? Because you do mention several providers where problems did occur. And the thing is: those are the known problems. If duplicacy trusts the storage backend by default, doesnā€™t that already minimize the chances such problems become known (before it is too late)?
While it is clear that trusting the backend is riskier than not trusting it, I am not in the position to assess how much riskier it is. Or perhaps: under what circumstances. Anyone?
As you asked for ā€œanyoneā€, then, my two cents:
There is no 100% fail-safe software / system, neither Dropbox, nor Duplicacy, nor Duplicati, or your NAS, and no other.
Of course there are systems theoretically more reliable than others, but in the real world you donā€™t have easy access to system data to confirm this reliability.
So what we have to do is take actions under our control to minimize or mitigate the risks. The more measures, or more complex, the safer it gets but also more expensive.
For example: To mitigate the risk of ā€œtrusting the backendā€, I can periodically download random files and compare them with the production environment files. Itā€™s cheap (free), and it minimizes the risk a little.
Or I can dilute the risk by backing up to multiple destinations (can be more expensive depending on how you will set it up).
In an airplane, to mitigate risks, systems are redundant. An airplane has two or three parallel hydraulic systems. If one fails, the other system takes over. Extremely expensive, but necessary.
So in my opinion, itā€™s not a ā€œtrusting vs not trustingā€ issue. The question is: how much are you willing to spend to mitigate your risk?
Exactly, that is my point. In order to answer that question, you need to understand ā€œyour riskā€. More specifically: what kind of damage can occur, how serious is it, and how likely is it to occur. In the case of the airplane, the potential damage is quite clear: people die and it is is so high, that one is willing to accept the very high mitigation costs, even though the failure of a hydraulic system (let alone two) is quite low.
So with the backups, what might happen and how likely is it? Total data loss? Partial data loss? Corrupted data, making restore a pain?
Though it is fair to mention that most cloud storage providers du have multiple redundancies across multiple data centres. So we are not really talking about that kind of loss due to hardware failure. What we need to worry about is basically software failure, like the server returning ā€œOKā€ although the data has not been saved correctly. So this is basically what Iā€™m after: what kind of software failures are we up against?
The ā€œtrusting vs not trustingā€ decision affects the implementation of backup software. If we determine the storage can be trusted, weā€™ll just implement some verification scheme to catch the error should such an error occur, otherwise we need to implement correction (like PAR2 error correction) on top of verification.
I agree that from a point of view of an end user, no system can be trusted 100%. The addition of a backup software as the middle layer only makes it worse if the software is ill-devised. The only weapon against failures is hash verification. There are two types of hashes in Duplicacy, chunk hashes and file hashes. With chunk hashes we know for sure that a chunk we download is the same as what we uploaded. With the file hash we can be confident once we are able to restore a file with the correct file hash that we have restored correctly what was backed up. Of course, there can be some cases that may not be detected by hash verification (for instance, if there is a bug in reading the file during backup) but that is very unlikely.
Continuing the tests ā€¦
One of the goals of my use for Duplicati and Duplicacy is to back up large files (some Gb) that are changed in small parts. Examples: Veracrypt volumes, mbox files, miscellaneous databases, and Evernote databases (basically an SQLite file).
My main concern is the growth of the space used in the backend as incremental backups are performed.
I had the impression that Duplicacy made large uploads for small changes, so I did a little test:
I created an Evernote installation from scratch and then downloaded all the notes from the Evernote servers (about 4,000 notes, the Evernote folder was then 871 Mb, of which 836 Mb from the database).
I did an initial backup with Duplicati and an initial backup with Duplicacy.
Results:
Duplicati:
672 Mb
115 min
and
Duplicacy:
691 Mb
123 min
Pretty much the same, but with some difference in size.
Then I opened Evernote, made a few minor changes to some notes (a few Kb), closed Evernote, and ran backups again.
Results:
Duplicati (from the log):
BeginTime: 21/01/2018 22:14:41
EndTime: 21/01/2018 22:19:30 (~ 5 min)
ModifiedFiles: 5
ExaminedFiles: 347
OpenedFiles: 7
AddedFiles: 2
SizeOfModifiedFiles: 877320341
SizeOfAddedFiles: 2961
SizeOfExaminedFiles: 913872062
SizeOfOpenedFiles: 877323330
and
Duplicacy (from the log):
Files: 345 total, 892,453K bytes; 7 new, 856,761K bytes
File chunks: 176 total, 903,523K bytes; 64 new, 447,615K bytes, 338,894K bytes uploaded
Metadata chunks: 3 total, 86K bytes; 3 new, 86K bytes, 46K bytes uploaded
All chunks: 179 total, 903,610K bytes; 67 new, 447,702K bytes, 338,940K bytes uploaded
Total running time: 01:03:50
Of course it jumped several chunks, but still uploaded 64 chunks of a total of 176!
I decided to do a new test: I opened Evernote and changed one letter of the contents of one note.
And I ran the backups again. Results:
Duplicati:
BeginTime: 21/01/2018 23:37:43
EndTime: 21/01/2018 23:39:08 (~1,5 min)
ModifiedFiles: 4
ExaminedFiles: 347
OpenedFiles: 4
AddedFiles: 0
SizeOfModifiedFiles: 877457315
SizeOfAddedFiles: 0
SizeOfExaminedFiles: 914009136
SizeOfOpenedFiles: 877457343
and
Duplicacy (remembering: only one letter changed):
Files: 345 total, 892,586K bytes; 4 new, 856,891K bytes
File chunks: 178 total, 922,605K bytes; 26 new, 176,002K bytes, 124,391K bytes uploaded
All chunks: 181 total, 922,692K bytes; 29 new, 176,088K bytes, 124,437K bytes uploaded
Total running time: 00:22:32
In the end, the space used in the backend (contemplating the 3 versions, of course) was:
Duplicati: 696 Mb
Duplicacy: 1,117 Mb
That is, with these few (tiny) changes Duplicati added 24 Mb to the backend and Duplicacy 425 Mb.
Only problem: even with a backup so simple and small, in the second and third execution Duplicati showed me a ā€œwarningā€, but I checked the log and:
Warnings: []
Errors: []
It seems to me a behavior already known to Duplicati. What worries me is to ignore the warnings and fail to see a real warning.
Now Iā€™m here evaluating the technical reason for such a big difference, thinking about how Duplicati and Duplicacy backups are structured. Any suggestion?
Interesting. I know the evernote data directory is just a big sqlite database and a bunch of very small files. The default chunk size in Duplicati is 100K, and 4M in Duplicacy. While 100K would be too small for Duplicacy, I wonder if you can run another test with the default size set to 1M:
duplicacy init -c 1M repository_id storage_url
Or even better, since it is a database, you can switch to the fixed-size chunking algorithm by calling this init command:
duplicacy init -c 1M -max 1M -min 1M repository_id storage_url
In fact, I would recommend this for backing up databases and virtual machines, as this is the default setting we used in Vertical Backup.
OK! I deleted all backup files from the backend (Dropbox), I also deleted all local configuration files (preferences, etc.).
I ran the init command with the above parameters (second option, similar to Vertical Backup) and Iā€™m running the new backup. As soon as itā€™s finished Iā€™ll post the results here.
Iā€™m following up the backup and itā€™s really different (as expected), since with the previous configuration it ran several packing commands and then an upload, and now itā€™s almost 1:1, a packing and an upload.
But I noticed something: even with the chunk size fixed, they still vary in size, some have 60kb, some 500Kb, etc. None above 1Mb. Should not they all be 1024?
Everything was going well until it started to upload the chunks for the database, so he stopped:
Packing Databases/.accounts
Uploaded chunk 305 size 210053, 9KB/s 1 day 03:08:51 0.8%
Packed Databases/.accounts (28)
Packing Databases/.sessiondata
Uploaded chunk 306 size 164730, 9KB/s 1 day 02:40:56 0.8%
Packed Databases/.sessiondata (256)
Packing Databases/lgtbox.exb
Uploaded chunk 307 size 231057, 9KB/s 1 day 01:58:44 0.8%
Uploaded chunk 308 size 28, 9KB/s 1 day 02:04:33 0.8%
Uploaded chunk 309 size 256, 9KB/s 1 day 02:08:27 0.8%
Uploaded chunk 310 size 1048576, 11KB/s 23:12:09 0.9%
Uploaded chunk 311 size 1048576, 12KB/s 20:56:24 1.0%
Uploaded chunk 312 size 1048576, 13KB/s 19:10:50 1.1%
Uploaded chunk 313 size 1048576, 14KB/s 17:36:14 1.3%
Uploaded chunk 314 size 1048576, 15KB/s 16:34:14 1.4%
Uploaded chunk 441 size 1048576, 61KB/s 03:23:18 15.9%
Uploaded chunk 442 size 1048576, 62KB/s 03:22:16 16.1%
Failed to upload the chunk 597ec712d6954c9d4cd2d64f38857e6b198418402d2aaef6f6c590cacb5af31d: Post https://content.dropboxapi.com/2/files/upload: EOF
Incomplete snapshot saved to C:\_Arquivos\Duplicacy\preferences\NOTE4_Admin_Evernote-dropbox/incomplete
I tried to continue the backup and:
Incomplete snapshot loaded from C:\_Arquivos\Duplicacy\preferences\NOTE4_Admin_Evernote-dropbox/incomplete
Listing all chunks
Listing chunks/
Listing chunks/48/
Listing chunks/8e/
Listing chunks/03/
Listing chunks/f4/
Listing chunks/2b/
Failed to list the directory chunks/2b/:
I tried again to run and now itā€™s going ā€¦
Skipped chunk 439 size 1048576, 19.77MB/s 00:00:38 15.8%
Skipped chunk 440 size 1048576, 19.91MB/s 00:00:37 15.9%
Skipped chunk 441 size 1048576, 20.05MB/s 00:00:37 16.1%
Uploaded chunk 442 size 1048576, 6.73MB/s 00:01:49 16.2%
Uploaded chunk 443 size 1048576, 4.45MB/s 00:02:44 16.3%
Uploaded chunk 444 size 1048576, 2.99MB/s 00:04:04 16.4%
The new ā€œinitialā€ backup is completed, and it took much longer than with the previous setup:
Backup for C:_Arquivos\Evernote at revision 1 completed
Files: 345 total, 892,586K bytes; 344 new, 892,538K bytes
File chunks: 1206 total, 892,586K bytes; 764 new, 748,814K bytes, 619,347K bytes uploaded
Metadata chunks: 3 total, 159K bytes; 3 new, 159K bytes, 101K bytes uploaded
All chunks: 1209 total, 892,746K bytes; 767 new, 748,973K bytes, 619,449K bytes uploaded
Total running time: 02:39:20
It ended up with 1206 file chunks (the previous was 176), which was expected.
Then I opened Evernote and it synchronized a note from the server (an article I had captured this morning), which lasted 2 seconds and added a few kb, see the log:
14:03:13 [INFO   ] [2372] [9292] 0% Retrieving 1 note
14:03:13 [INFO   ] [2372] [9292] 0% Retrieving note "AutomaĆ§Ć£o vai mudar a carreira de 16 ..."
14:03:13 [INFO   ] [2372] [9292] 0% * guid={6a4d9939-8721-4fb5-b9d1-3aa6a045266f}
14:03:13 [INFO   ] [2372] [9292] 0% * note content, length=0
14:03:13 [INFO   ] [2372] [9292] 0% Retrieving resource, total size=31053
14:03:13 [INFO   ] [2372] [9292] 0% * guid={827bb525-071c-40f3-9c00-1e82b60f4136}
14:03:13 [INFO   ] [2372] [9292] 0% * note={6a4d9939-8721-4fb5-b9d1-3aa6a045266f}
14:03:13 [INFO   ] [2372] [9292] 0% * resource data, size=31053
14:03:14 [INFO   ] [2372] [7112] 100% Updating local note "AutomaĆ§Ć£o vai mudar a carreira de 16 ...", resource count: 4, usn=0
14:03:15 [INFO   ] [2372] [7112] 100% * guid={6A4D9939-8721-4FB5-B9D1-3AA6A045266F}
14:03:15 [INFO   ] [2372] [7112] 100% Updating local resource "363cd3502354e5dbd4e95e61e387afe2", 31053 bytes
The Evernote folder, which was like this:
before
becomed like this
after
So I ran a new backup with Duplicati:
BeginTime: 22/01/2018 16:07:50
EndTime: 22/01/2018 16:10:50 (~ 3 min)
ModifiedFiles: 3
ExaminedFiles: 349
OpenedFiles: 5
AddedFiles: 2
SizeOfModifiedFiles: 877567112
SizeOfAddedFiles: 21073
SizeOfExaminedFiles: 914374437
SizeOfOpenedFiles: 877588213
and a new backup with Duplicacy:
Files: 346 total, 892,943K bytes; 4 new, 857,019K bytes
File chunks: 1207 total, 892,943K bytes; 74 new, 73,659K bytes, 45,466K bytes uploaded
All chunks: 1210 total, 893,103K bytes; 77 new, 73,819K bytes, 45,568K bytes uploaded
Total running time: 00:14:16
A much better result than with the initial setup, but still, much longer runtime and twice as many bytes sent.
The question now is: can (should?) I push the limits and reconfigure chunks size to 100K?
In Duplicacy the chunk size must be a power of 2, so it has to 64K or 128K.
Generally a chunk size that is too small is not recommended for two reasons: it will create too many chunks on the storage, and the overhead of chunk transfer becomes significant. However, if the total size of your repository is less than 1G, a chunk size of 64K or 128K wonā€™t create too many chunks. The overhead factor can be mitigated by using multiple threads.
Unfortunately, Dropbox doesnā€™t like multiple uploading threads ā€“ it will complain about too many write requests if you attempt to do this. But, since in this test your main interest is the storage efficiency, I think you can just use a local storage and you can complete the run in minutes rather than hours.
Here is another thing you may be interested. Can you run Evernote on another computer and download the database there and then back up to the same storage? Iā€™m not sure if the databases on two computers can be deduplicated ā€“ it depends on how Evernote creates the sqlite database, but it may be worth a try.
Nope, the idea is to do an off-site backup. I already do a local backup.
Iā€™ll try 128k with Dropboxā€¦
Very interesting results! Thangs a lot, towerbr, for the testing.
So the smaller chunk size leads to better results in the case of db files. But since the default chunk size is much bigger, I assume that for other types of backups, the smaller chunk size will create other problems? Does this mean I should exclude db files (does anyone have a regex?) from all my backups and create a separate backup for those (possibly one for each repository)? Not very convenient, but I guess weā€™re seeing a clear downside of the duplicacyā€™s killer feature, cross repository deduplicationā€¦
Another question concerning duplicacyā€™s storage use:
Duplicati: 696 Mb Duplicacy: 1,117 Mb
Unless Iā€™m misunderstanding something, that difference will we significantly reduced, once you run a prune operation, right?
But then again, you will only save space at the cost of eliminating a revision compared to duplicati. So the original comparison is fair. Ironically, this means that duplicati is actually doing a (much) better job at deduplication between revisionsā€¦
Hm, this actually further worsens the space use disadvantage of duplicacy: I believe the original tests posted on the duplicati forum did not include multiple revisions. Now we know that the difference in storage use will actually increase exponentially over time (i.e. with every revision), especially when small changes are made in large files.
for each repository)? Not very convenientā€¦
Exact! In the case of this test, I think the solution would be to make an init with the normal chunk size (4M) for the Evernote folder with an exclude for the database, and an add with smaller chunk (128k maybe) to contemplate only the database via include.
The problem is that in the case of Evernote it is very easy to separate via include / exclude pattern because it is only one SQLite file. But for other applications, with multiple databases, it is not practical. And itā€™s also not practical for mbox files, for example.
So, in the end, I would leave with only one configuration (128k) applied to the whole folder (without add), which is what I am testing now.
ā€¦ the difference in storage use will actually increase exponentially
This is exactly my main concern.
Are you worried that it might be so and are testing it, or do you think it is so but are sticking to duplicacy for other reasons?
Iā€™m testing Duplicacy and Duplicati for backing up large files. At the moment I have some jobs of each one running daily. I havenā€™t decided yet.
In a very resumed way:
Duplicati has more features (which on the other hand exposes it to more failure points) and seems to me to deal better with large files (based on the performance of my jobs and this test so far). But the use of local databases and the constant warnings are the weak points.
Duplicacy seems to me a simpler and more mature software, with some configuration difficulty (init, add, storages, repositories, etc), but it starts to worry me about backups of large files.
