Thanks for the tips. I’ve tried with the + and without. I receive the same result on any file that’s within the boundaries of selections that will not restore (which is most of the files). I’ve tested with the + and without for files that will restore and it works either way. I can conclude the addition of the + has no effect whether a file will or won’t restore.
I can confirm I am not typing the filename by hand and am retrieving it directly from the restore attempt logs when the unsuccessful attempt is staged from the GUI. I’ve also retrieved it from the exlusion filters when specifying -d when it attempts to restore and shows it’s excluded. We’re working with this file for the purposes of this demonstration but I can assure you this filename exists, is correct, and the behavior is exhibited with other files.
Thanks for everyone’s help trying to work through this. I’m ready to purchase a business license because I believe in this product and like the community of support. I just want to get past this pretty large issue before doing such and unfortunately my trial is up tomorrow.
