I want to say thank you gchen! Everything is working great so far and I will be purchasing!
Quick question, best practice for backing up multiple directoriesâŚ
Every directory gets its own seperate backupid correct?
And also, I want to be able to backup all the directories at 1AM. So I set up a single schedule and just add the multiple backups, but do I set them all to run in parallel? If I donât and another backup is not yet finished, and the time comes again, will it just be skipped, or does it automatically just go to the next folder once the first one is finished?
Thank you again very much, your software has been the best!
