OneDrive token - Can it be downloaded from anywhere and used on more than one PC?
Re downloading the OneDrive token, does that need to be performed on the machine that will be running Duplicacy?
And if not, can i use the same token on more than one device? I am to backup my parent’s 2 computers to their OneDrive space. So i’d like to download the token, take it to their place, plonk it on the devices and perform the procedure.
Cheers.
Yes, the token file can be used on other computers.
