Timo, I issued the full refund of your two licenses on stripe.com and you should be able to see it on your credit card statement in a couple of days. If you don’t, please let me know.
Sorry to lose you as a customer, but I should clarify that it is possible to check chunks automatically after each backup – we just don’t make this the default. You can create a post-backup script that runs the check command to make sure that every chunk just uploaded does exist. This will catch any missing chunk error much earlier.
In most cases when users reported missing chunks, the cause was always the misuse of the -exclusive option (for example here and here. However, in your case I tend to believe it is the issue of the Paragon ext4 driver, mostly because of the weird listing bug. If so, then it would have been caught by the post-backup check script.
On how to recover from missing chunks – sorry I was wrong on the use of the -hash option. I forgot that the -hash option still assumes that the chunks referenced by last snapshot all exist. The correct way is run the backup command with a different repository id (by editing the .duplicacy/preferences file). After the repairing backup command you can change the repository id back to the original one. Then you can remove the snapshot file snapshots/temporary_id/1 from the storage. If no files changed before this repairing backup command then no unreferenced chunks will be generated by this operation.
It should be noted that repairing missing chunks isn’t guaranteed to work every time. If some files have changed then it will be impossible to regenerate the missing chunks. To be able to recover from missing chunks under any circumstances requires the error correction technique, which incurs significant overhead on most storage systems that can be reasonably trusted. If you’re really worried about this issue, then you should back up to multiple storages.
Kevinvinv, I disagree with you on the reason that the copy function should be avoided. If you back up to two storages independently and some files changed between these two backups then you will not get the same set of chunks on different storages. So when one chunk is missing on one storage you can’t grab it from the other storage. Another advantage of the copy function is that you can use third-party tools like rsync/rclone to copy chunks between storages.
