When I attempt to get a trial license, it says "this computer is not elibible for the 30 day trial. It’s a windows 7 VM, and I changed the host name to something unique, but it still won’t work.
thanks,
thanks,
I found out the license request from your machine and reset the trial license. It should be good now.
For anyone: Feel free to use the button on the posts that you found useful.
For the OP of any support topic: you can mark the post that solved your issue by ticking the box under the post. That of course may include your own post
