What is the comment global option supposed to do? It says that it’s purpose is
Now, to start with, it seems that the documentation is not 100% correct:
Shouldn’t it be comment <argument>? Because if I try duplicacy -commend check I get Incorrect usage but if I give it an argument, like so: duplicacy -comment test check, the command executes. However, I can't see any effect sof the-comment option` when I look at the Task Manager. All duplicacy processes still look the same…
That is how I see it… just my opinion of course. So if I had any sort of say… I would go with process-label obviously
