I’m curious if duplicacy web 1.5 is considered stable.
https://duplicacy.com/latest_web_version shows as 1.4.1 as being stable and 1.5.0 as being latest.
Cheers
Cheers
This has been fixed. I should have updated the version a while ago.
hey! Sorry to bring this up again. It’s just that hotio docker image uses that link for determining which version to include latest is stable enough to use?
This API was specifically added
to report stable and latest versions to simplify deployments in automation.
My understanding is it’s a manual process and while latest version is literally latest available one, the stable version is up to per gchen’s determination.
What and how hotio is using it I can’t comment.
Understood, just last time it wasn’t updated for a very long time and since it’s not automated more of a reminder! Since 1.6.x has been released for a 2 months i figured it might be worth it to update. And 1.6.x is latest it seems like it should be there but isn’t as well.
Cheers
https://duplicacy.com/latest_web_version now returns 1.6.2 as the latest version.
Wanted to look and see, is 1.8.3 stable?
shows that 1.8.0 is stable but 1.8.3 isn’t
