401 response from Backblaze
Using Duplicacy WebUI via Unraid to create Backblaze B2 storage
KeyID and AppKey seem to authenticate because the desired bucket populates, but errors out when clicking Continue to add.
Via log:
2021/12/17 15:29:01 TRACE BACKBLAZE_CALL [0] URL request ‘POST https://api.backblazeb2.com/b2api/v1/b2_authorize_account’ returned 401
2021/12/17 15:29:01 ERROR STORAGE_CREATE Failed to load the Backblaze B2 storage at b2://: Authorization failure
2021/12/17 15:29:01 Failed to check the storage at b2://eyeCandyPhotography: Failed to load the Backblaze B2 storage at b2://: Authorization failure
Tried deleting and recreating bucket. Confirmed that application ID has access to all buckets (only one bucket exists) and is set to ‘Read and Write.’ Disabling encryption on bucket also made no difference.
Can you access the same bucket with another app, such as CyberDuck or Transmit, using the same credentials?
It’s either wrong credentials or backblaze outage.
