Ability to use -hash option with GUI
Hello,
Is there a possibility to add an option to use -hash in the GUI.
(duplicacy backup -hash)
because I have trouble only with date and size of a file.
My example : I took a photo, then change the exif information. The date and size of the file is the same and duplicacy doesn’t backup it without -hash.
I could use the command line executable but I decided to buy the GUI license so I would appreciate to have this.
Best Regards.
Hello again, additionally can you change my displayname on this forum to
roranippon
I didn’t know it was for ever when I typed it.
Best Regards.
Hello,
And again, I think that I found that by default it is with -hash command ? I saw that in the revision in restore.
Is that correct ?
Best Regards
The -hash option is only enabled by default for the initial backup (since there is no previous backup to compare the dates and sizes with). I’ll add this option to the GUI version 2.1.0.
Hello,
Thank you very much.
Best Regards.
