What are the requirements for the RSA encryption does it only support lengths of 2048 as in the tutorial or also 4096, for example.
Also, are other asymmetric encryption methods supported as well, eg. ECDSA?
F
F
Only RSA encryption is supported, but you can use a private key of any length.
