Hello,
I’m trying to set up duplicacy web on my TrueNAS Scale server and I’m running into some problems getting it to auto start and also continue running without a shell. I can log in and run the binary and everything works fine, but if I try to run it in the background with nohup and then disown the process to log out, I get the following errors when backups attempt to run:
Running backup command from /root/.duplicacy-web/repositories/localhost/0 to back up /mnt/default
Options: [-log backup -storage b2 -threads 20 -stats]
fork/exec /root/.duplicacy-web/bin/duplicacy_linux_x64_3.2.3: function not implemented
Regarding auto starting, I tried to add a post-init task in the TrueNAS Web UI which does launch duplicacy web, however it does not see /root/.duplicacy-web at all and cannot initialize it somewhere else because the root partition is read-only on TrueNAS scale:
AFAIK this also means you can’t create a systemd service like others have recommended.
So, has anyone managed to achieve this? Is there some undocumented flag for the duplicacy-web binary that allows you to point it at a .duplicacy-web folder?
