We were running the duplicacy check command against an AWS S3 storage backend and noticed that the chunks could not be found. As it turned out we didn’t give the right permissions for the Amazon IAM role associated with duplicacy and therefore received a 403 from AWS. However duplicacy reported that the chunk was not found and this lead us to think in the wrong direction. I saw that this is an intended behaviour as it swallows 403 errors here:
I would expect to see an error message that indicates insufficient permissions - I would return the error in the first if-branch above.
I saw the error message that a certain chunk could not be found.
As this is clearly an intended behavior and I’m presumably missing something here, so I’d be glad if you could elaborate why the 403 is caught that way.
Thanks for your work
