Scheduled is once per night. Occasionally, or when testing changes, I’ll manually run the backup. The vast majority of the last two months would have had only single revision per day.
Running check command from /root/.duplicacy-web/repositories/localhost/all
Options: [-log check -storage b2-backup -a -tabular]
2024-03-15 09:00:39.556 INFO STORAGE_SET Storage set to b2://bucket
2024-03-15 09:00:39.706 INFO BACKBLAZE_URL Download URL is: https://f999.backblazeb2.com
2024-03-15 09:00:40.512 INFO SNAPSHOT_CHECK Listing all chunks
2024-03-15 09:01:09.772 INFO SNAPSHOT_CHECK 2 snapshots and 34 revisions
2024-03-15 09:01:09.773 INFO SNAPSHOT_CHECK Total chunk size is 23,925M in 4930 chunks
2024-03-15 09:01:09.785 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back02 at revision 389 exist
2024-03-15 09:01:09.791 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back02 at revision 435 exist
2024-03-15 09:01:09.796 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back02 at revision 470 exist
2024-03-15 09:01:09.802 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back02 at revision 507 exist
2024-03-15 09:01:09.808 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back02 at revision 541 exist
2024-03-15 09:01:09.813 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back02 at revision 546 exist
2024-03-15 09:01:09.819 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back02 at revision 553 exist
2024-03-15 09:01:09.824 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back02 at revision 560 exist
2024-03-15 09:01:09.829 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back02 at revision 567 exist
2024-03-15 09:01:09.835 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back02 at revision 572 exist
2024-03-15 09:01:09.841 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back02 at revision 573 exist
2024-03-15 09:01:09.846 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back02 at revision 574 exist
2024-03-15 09:01:09.851 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back02 at revision 575 exist
2024-03-15 09:01:09.858 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back02 at revision 578 exist
2024-03-15 09:01:09.863 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back02 at revision 582 exist
2024-03-15 09:01:09.869 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back02 at revision 583 exist
2024-03-15 09:01:10.504 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back02 at revision 584 exist
2024-03-15 09:01:10.504 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back01 at revision 389 exist
2024-03-15 09:01:10.504 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back01 at revision 435 exist
2024-03-15 09:01:10.504 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back01 at revision 470 exist
2024-03-15 09:01:10.504 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back01 at revision 507 exist
2024-03-15 09:01:10.504 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back01 at revision 541 exist
2024-03-15 09:01:10.504 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back01 at revision 546 exist
2024-03-15 09:01:10.504 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back01 at revision 553 exist
2024-03-15 09:01:10.504 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back01 at revision 560 exist
2024-03-15 09:01:10.504 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back01 at revision 567 exist
2024-03-15 09:01:10.504 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back01 at revision 572 exist
2024-03-15 09:01:10.505 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back01 at revision 573 exist
2024-03-15 09:01:10.505 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back01 at revision 574 exist
2024-03-15 09:01:10.505 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back01 at revision 575 exist
2024-03-15 09:01:10.505 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back01 at revision 578 exist
2024-03-15 09:01:10.505 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back01 at revision 582 exist
2024-03-15 09:01:10.505 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back01 at revision 583 exist
2024-03-15 09:01:10.505 INFO SNAPSHOT_CHECK All chunks referenced by snapshot back01 at revision 584 exist
2024-03-15 09:01:10.691 INFO SNAPSHOT_CHECK
back01 | 389 | @ 2023-09-19 08:41 | 5 | 8K | 5 | 4K | 0 | 0 | 5 | 4K |
back01 | 435 | @ 2023-10-24 08:44 | 5 | 8K | 5 | 4K | 0 | 0 | 0 | 0 |
back01 | 470 | @ 2023-11-28 08:41 | 5 | 8K | 5 | 4K | 0 | 0 | 0 | 0 |
back01 | 507 | @ 2024-01-02 08:41 | 5 | 8K | 5 | 4K | 0 | 0 | 0 | 0 |
back01 | 541 | @ 2024-02-06 08:42 | 5 | 8K | 5 | 4K | 0 | 0 | 0 | 0 |
back01 | 546 | @ 2024-02-11 08:45 | 5 | 8K | 5 | 4K | 0 | 0 | 0 | 0 |
back01 | 553 | @ 2024-02-18 08:42 | 5 | 8K | 5 | 4K | 0 | 0 | 0 | 0 |
back01 | 560 | @ 2024-02-25 08:40 | 5 | 8K | 5 | 4K | 0 | 0 | 0 | 0 |
back01 | 567 | @ 2024-03-03 08:41 | 5 | 8K | 5 | 4K | 0 | 0 | 0 | 0 |
back01 | 572 | @ 2024-03-08 08:42 | 5 | 8K | 5 | 4K | 0 | 0 | 0 | 0 |
back01 | 573 | @ 2024-03-09 08:42 | 5 | 8K | 5 | 4K | 0 | 0 | 0 | 0 |
back01 | 574 | @ 2024-03-10 08:46 | 5 | 8K | 5 | 4K | 0 | 0 | 0 | 0 |
back01 | 575 | @ 2024-03-11 08:41 | 5 | 8K | 5 | 4K | 0 | 0 | 0 | 0 |
back01 | 578 | @ 2024-03-12 03:36 | 5 | 8K | 5 | 4K | 0 | 0 | 0 | 0 |
back01 | 582 | @ 2024-03-13 08:42 | 5 | 8K | 5 | 4K | 0 | 0 | 0 | 0 |
back01 | 583 | @ 2024-03-14 08:41 | 5 | 8K | 5 | 4K | 0 | 0 | 0 | 0 |
back01 | 584 | @ 2024-03-15 08:42 | 5 | 8K | 5 | 4K | 0 | 0 | 0 | 0 |
back01 | all | | | | 5 | 4K | 5 | 4K | | |
back02 | 389 | @ 2023-09-19 08:41 | 159086 | 17,677M | 3523 | 16,504M | 1062 | 5,342M | 3523 | 16,504M |
back02 | 435 | @ 2023-10-24 08:43 | 159089 | 16,653M | 3343 | 15,483M | 73 | 440,285K | 882 | 4,321M |
back02 | 470 | @ 2023-11-28 08:41 | 159095 | 16,656M | 3352 | 15,491M | 35 | 213,470K | 82 | 448,096K |
back02 | 507 | @ 2024-01-02 08:41 | 159095 | 16,656M | 3349 | 15,490M | 29 | 207,290K | 41 | 278,282K |
back02 | 541 | @ 2024-02-06 08:41 | 159095 | 16,656M | 3355 | 15,490M | 25 | 177,434K | 38 | 226,728K |
back02 | 546 | @ 2024-02-11 08:43 | 159095 | 16,656M | 3354 | 15,490M | 22 | 162,095K | 22 | 162,095K |
back02 | 553 | @ 2024-02-18 08:41 | 159095 | 16,656M | 3354 | 15,491M | 26 | 183,088K | 28 | 199,096K |
back02 | 560 | @ 2024-02-25 08:40 | 159095 | 16,656M | 3354 | 15,490M | 23 | 162,095K | 27 | 191,133K |
back02 | 567 | @ 2024-03-03 08:41 | 159095 | 16,656M | 3348 | 15,490M | 50 | 283,285K | 52 | 295,510K |
back02 | 572 | @ 2024-03-08 08:41 | 159095 | 16,656M | 3358 | 15,490M | 29 | 172,214K | 62 | 299,476K |
back02 | 573 | @ 2024-03-09 08:41 | 159095 | 16,656M | 3359 | 15,490M | 31 | 179,871K | 31 | 179,871K |
back02 | 574 | @ 2024-03-10 08:44 | 159095 | 16,656M | 3353 | 15,490M | 29 | 185,655K | 29 | 185,655K |
back02 | 575 | @ 2024-03-11 08:41 | 159095 | 16,656M | 3352 | 15,490M | 0 | 0 | 32 | 201,976K |
back02 | 578 | @ 2024-03-12 03:36 | 159095 | 16,656M | 3352 | 15,490M | 0 | 0 | 0 | 0 |
back02 | 582 | @ 2024-03-13 08:41 | 159095 | 16,656M | 3351 | 15,490M | 23 | 161,725K | 23 | 161,725K |
back02 | 583 | @ 2024-03-14 08:41 | 159095 | 16,656M | 3349 | 15,490M | 24 | 174,569K | 24 | 174,569K |
back02 | 584 | @ 2024-03-15 08:41 | 159095 | 16,656M | 3356 | 15,490M | 29 | 169,383K | 29 | 169,383K |
back02 | all | | | | 4925 | 23,925M | 4925 | 23,925M | | |
