B2 storage: bucket not found error
Duplicacy 1.1.4 on macOS 10.12.1. Message when connecting to B2: “ERROR Failed to load the Backblaze B2 storage at b2://[∫Bucket ID]: Bucket [Bucket ID] not found”
Double checked Bucket ID in B2 portal, looks correct. Connecting to another bucket using Cloudberry (with same Account ID and Application key) works no problem.
Verbose log not enlightening I’m afraid:
14:27:48.000 Command: duplicacy -background -log -d init [my backup job] “b2://[Bucket ID]”
14:27:48.726 Reading the environment variable DUPLICACY_B2_ID
14:27:48.761 Reading the environment variable DUPLICACY_B2_KEY
Thanks
Does the bucket id contain any special characters?
Are you using Bucket ID or Bucket name? I don’t think the former works.
Right, you should enter the bucket name not the bucket id.
Indeed, Bucket Name it is, not ID. Was confused because other solutions (e.g. CloudBerry) need Bucket ID instead. Maybe add this to the GUI? Thanks for your help anyway.
