I’ve got a new issue as of last night, prune on BackBlaze storage fails to fully run, it hung up at 5:45AM and has been sitting at the same line in the log for hours.
Trying to re-run it now and I get stopped within a moment each time I try to run it.
It ends up being a different backup that the prune is running where it stops, but it’s always revision 65 for some reason…
Weird, but can’t seem to find out what is going wrong and how to fix this?
Options: [-log prune -storage Backblaze -keep 0:15 -all -exhaustive]
2021-01-27 09:23:20.630 INFO STORAGE_SET Storage set to b2://****************
2021-01-27 09:23:21.111 INFO BACKBLAZE_URL download URL is: https://f002.backblazeb2.com
2021-01-27 09:23:22.105 INFO RETENTION_POLICY Keep no snapshots older than 15 days
2021-01-27 09:23:31.518 INFO SNAPSHOT_DELETE Deleting snapshot Paperless at revision 15
2021-01-27 09:23:31.518 INFO SNAPSHOT_DELETE Deleting snapshot Paperless at revision 16
2021-01-27 09:23:31.518 INFO SNAPSHOT_DELETE Deleting snapshot Paperless at revision 17
2021-01-27 09:23:31.518 INFO SNAPSHOT_DELETE Deleting snapshot Paperless at revision 18
2021-01-27 09:23:31.518 INFO SNAPSHOT_DELETE Deleting snapshot Paperless at revision 19
2021-01-27 09:23:31.518 INFO SNAPSHOT_DELETE Deleting snapshot Paperless at revision 20
2021-01-27 09:23:31.537 INFO SNAPSHOT_DELETE Deleting snapshot Photos at revision 60
2021-01-27 09:23:31.537 INFO SNAPSHOT_DELETE Deleting snapshot Photos at revision 61
2021-01-27 09:23:31.537 INFO SNAPSHOT_DELETE Deleting snapshot Photos at revision 62
2021-01-27 09:23:31.537 INFO SNAPSHOT_DELETE Deleting snapshot Photos at revision 63
2021-01-27 09:23:31.537 INFO SNAPSHOT_DELETE Deleting snapshot Photos at revision 64
2021-01-27 09:23:31.537 INFO SNAPSHOT_DELETE Deleting snapshot Photos at revision 65
2021-01-27 09:23:32.081 INFO SNAPSHOT_DELETE Deleting snapshot AppData at revision 61
2021-01-27 09:23:32.081 INFO SNAPSHOT_DELETE Deleting snapshot AppData at revision 62
2021-01-27 09:23:32.081 INFO SNAPSHOT_DELETE Deleting snapshot AppData at revision 63
2021-01-27 09:23:32.081 INFO SNAPSHOT_DELETE Deleting snapshot AppData at revision 64
2021-01-27 09:23:32.081 INFO SNAPSHOT_DELETE Deleting snapshot AppData at revision 65
2021-01-27 09:23:32.081 INFO SNAPSHOT_DELETE Deleting snapshot AppData at revision 66
2021-01-27 09:23:32.427 INFO SNAPSHOT_DELETE Deleting snapshot Backups at revision 60
2021-01-27 09:23:32.427 INFO SNAPSHOT_DELETE Deleting snapshot Backups at revision 61
2021-01-27 09:23:32.427 INFO SNAPSHOT_DELETE Deleting snapshot Backups at revision 62
2021-01-27 09:23:32.427 INFO SNAPSHOT_DELETE Deleting snapshot Backups at revision 63
2021-01-27 09:23:32.427 INFO SNAPSHOT_DELETE Deleting snapshot Backups at revision 64
2021-01-27 09:23:32.427 INFO SNAPSHOT_DELETE Deleting snapshot Backups at revision 65
2021-01-27 09:23:33.390 INFO SNAPSHOT_DELETE Deleting snapshot Flash at revision 64
2021-01-27 09:23:33.390 INFO SNAPSHOT_DELETE Deleting snapshot Flash at revision 65
2021-01-27 09:23:33.390 INFO SNAPSHOT_DELETE Deleting snapshot Flash at revision 66
2021-01-27 09:23:33.390 INFO SNAPSHOT_DELETE Deleting snapshot Flash at revision 67
2021-01-27 09:23:33.390 INFO SNAPSHOT_DELETE Deleting snapshot Flash at revision 68
2021-01-27 09:23:33.390 INFO SNAPSHOT_DELETE Deleting snapshot Flash at revision 69
2021-01-27 09:23:33.404 INFO SNAPSHOT_DELETE Deleting snapshot Nextcloud at revision 60
2021-01-27 09:23:33.404 INFO SNAPSHOT_DELETE Deleting snapshot Nextcloud at revision 61
2021-01-27 09:23:33.404 INFO SNAPSHOT_DELETE Deleting snapshot Nextcloud at revision 62
2021-01-27 09:23:33.404 INFO SNAPSHOT_DELETE Deleting snapshot Nextcloud at revision 63
2021-01-27 09:23:33.404 INFO SNAPSHOT_DELETE Deleting snapshot Nextcloud at revision 64
2021-01-27 09:23:33.404 INFO SNAPSHOT_DELETE Deleting snapshot Nextcloud at revision 65
they ended up finishing normally after some time.
