Backing up to S3 Minio - Versioning question
Hello,
I have just now started using duplicacy and am backing up to my own minio instance.
I am currently wondering if I should use a versioned bucket or not. Goal would be also ransomware protection. Does anyone have any thoughts?
I usually do use versioned buckets when I just upload my own archives to protect them but I am unsure in this case since duplicacy as a backup program already does do versioning, just not sure if that would result in the same thing.
Would be great if anyone could help.
What threat are trying to protect against? What is the scenario? Keys compromised and someone deletes your duplicacy datastore?
Duplicacy does not support object locking, but you can use keys that don’t allow delete, and achieve similar outcome.
