I run a backup from web UI as usual. For three years the backup worked without problems.
Environment:
- MacOs 14.2.1
- Duplicacy Web Edition 1.7.2
From some point on, the backup started to fail. It fails on every run.
Machine resent, duplicacy reinstall and version update do not help.
The error message is:
2024-01-13 10:18:24.177 WARN OPEN_FAILURE Failed to open file for reading: open /tmp/snp_1489225686/Users/xxx/Library/Metadata/CoreSpotlight/NSFileProtectionCompleteUnlessOpen/index.spotlightV3/store.db: operation not permitted
2024-01-13 10:18:57.347 ERROR CHUNK_MAKER Failed to read 0 bytes: read /tmp/snp_1489225686/Users/xxx/Library/Mobile Documents/ZP9ZJ4EF3S~com~gingerlabs~Notability/NBOrganizers.plist: operation timed out
2024-01-13 10:18:57.780 INFO VSS_DELETE Shadow copy unmounted and deleted at /tmp/snp_1489225686
How can I resolve this issue?
Please help!
