I encounter a strange behaviour with my new SSD (external via USB 3.0). A backup command that worked before with a classic external hard drive produces errors now deep within the job (often after an hour or longer):
2023-07-13 20:25:41.752 ERROR CHUNK_MAKER Failed to read 0 bytes: read \\?\C:\ProgramData\.duplicacy-web\repositories\localhost\6\.duplicacy\shadow\MEDIA\iTunes-Ordner mit TV-Shows (DRM)\iTunes\iTunes Media\TV Shows\Breaking Bad\Season 5\01 Lebe frei oder stirb.m4v: A device which does not exist was specified.
2023-07-13 20:25:45.770 INFO VSS_DELETE The shadow copy has been successfully deleted
I’m not sure what happens. Seems like the drive had been (probably very briefly) disconnected from the PC? When I check the drive is (back?) there.I tried also without VSS to no avail.
The SSD is an SAMSUNG T7 secured by a password application.
I guess it’s an USB problem unrelated to Duplicacy but you never know (something with folder and/or file names or any other weird thing?).
Maybe someone has an idea what happens here. I couldn’t identify any USB culprit yet, be it a device or an associated driver.
I checked in an USB Logger to see if there was any unplug operation: Sometimes there was, but the error shows up even without any unplug event.
Thanks for any help!
