Why is there a drop down menu item in the UI for the ‘Path’? Isn’t the path fixed by selection of the ‘Backup’ in the drop down above?
It is mostly for cosmetic reason. Otherwise it would have been a readonly input which looks much differently than other elements.
Ok, I just found it confusing as that UI element is usually for a user to select something.
