How can I backup symlink using Web UI? Duplicati allows this via the switch follow-symlink.
Only the first-level symlinks under the directory to be backed up are followed; all other symlinks will be backed up as symlinks. There is no option to change this default behavior.
Thanks for your response. Well, in my case, it’s not even following the first-level symlink. Is there any log apart from the backup log that I need to check to isolate this?
You can add -d as the global option to the backup job. Then you’ll see every subdirectory that Duplicacy finds during the indexing phase.
