Backup virtual disks (qcow2 format)
I am running inside a docker container.
The host (a QNap NAS) is also running several virtual machines using qcow2 format for the virtual disks.
Can duplicacy backup the very large IMG files of the virtual disks?
What are some good practices for it?
Thanks,
Oscar
IMHO duplicacy should handle these large qcow2 image just fine, though it might take a lot of ram in the latest release if these files are extremely large.
Though gchen is working on a new release that uses less ram, it might take a while for the new release to come out.
Edit:
I was wrong about the memory usage part.
As @gchen has pointed out in the reply below, the memory usage of duplicacy is depended on number of files, not size of files.
My Nas has 64 Gb RAM with only 32 gb used by the system (including the vms) , so it should be fine correct?
Can it handle these files while the files are being used by running virtual machines?
I think 32GM ram is more than enough for duplicacy.
No, you have to create a snapshot of these files, either by using qemu/kvm’s builtin snapshot capability, or by stopping the vm and create a copy of these images on disk, resume thse vm and back these copied files up.
You’ll probably also want to initialise the Duplicacy storage with fixed-sized chunks for this type of data (scroll down to ‘Fixed Size Chunking’):
Extremely large files won’t cause high memory usage – it is the number of files that determines the memory usage.
Thanks for pointing that out.
I’ve edited my reply to correct it.
