This has been going on for some time, just finally annoyed enough to report it.
Running Web-UI v1.2.1 in a docker container.
I have 2 backups scheduled - one daily @ 10pm, and another 8am M-W-F. When I edit the backup and save it, the backups get scheduled and run just fine - for a week or two. Then they just stop getting scheduled.
No error that I can see/find - they simply aren’t getting scheduled to run. Manually running the backup succeeds with no issues. Editing the backup and re-saving makes it run again - for a while.
Anything I can do about this? I’m getting tired of logging into the web UI to edit the jobs every week or two to keep things running - this really should be ‘set it and forget it’ (at least in terms of the backup jobs running).
The backups show a correct “next run time” when I look at the backup config. But they don’t run after running for a week or so.
Maybe there is an error in a log I’m not looking at/seeing? There are no log files generated at all on the days the backups don’t run, though.
