I am having several errors indicating “Failed to decrypt…” various times. This is with Debian 9 on ARM64 using the ARM version of the web-ui. I don’t know what this dbus error means since it seems quite vague or doesn’t provide beginners with much info for fixing.
Here is some output from duplicacy_web.log indicating the problem:
2019/06/07 17:09:44 Failed to decrypt the testing data using the password from KeyChain/Keyring: crypto/aes: invalid key size 0
2019/06/07 19:54:12 Failed to get the value from the keyring: keyring/dbus: Error connecting to dbus session, not registering SecretService provider: dbus: DBUS_SESSION_BUS_ADDRESS not set
2019/06/07 19:54:12 Failed to decrypt the testing data using the password from KeyChain/Keyring: crypto/aes: invalid key size 0
2019/06/07 19:54:39 Failed to store the value to the keyring: keyring/dbus: Error connecting to dbus session, not registering SecretService provider: dbus: DBUS_SESSION_BUS_ADDRESS not set
2019/06/10 08:26:21 Failed to get the value from the keyring: keyring/dbus: Error connecting to dbus session, not registering SecretService provider: dbus: DBUS_SESSION_BUS_ADDRESS not set
2019/06/10 08:26:21 Failed to decrypt the testing data using the password from KeyChain/Keyring: crypto/aes: invalid key size 0
2019/06/10 08:46:31 Failed to store the value to the keyring: keyring/dbus: Error connecting to dbus session, not registering SecretService provider: dbus: DBUS_SESSION_BUS_ADDRESS not set
2019/06/11 19:29:12 Failed to get the value from the keyring: keyring/dbus: Error connecting to dbus session, not registering SecretService provider: dbus: DBUS_SESSION_BUS_ADDRESS not set
2019/06/11 19:29:12 Failed to decrypt the testing data using the password from KeyChain/Keyring: crypto/aes: invalid key size 0
2019/06/11 19:55:50 Failed to store the value to the keyring: keyring/dbus: Error connecting to dbus session, not registering SecretService provider: dbus: DBUS_SESSION_BUS_ADDRESS not set
2019/06/12 05:16:11 Failed to get the value from the keyring: keyring/dbus: Error connecting to dbus session, not registering SecretService provider: dbus: DBUS_SESSION_BUS_ADDRESS not set
2019/06/12 05:16:11 Failed to decrypt the testing data using the password from KeyChain/Keyring: crypto/aes: invalid key size 0
2019/06/12 05:16:30 Failed to store the value to the keyring: keyring/dbus: Error connecting to dbus session, not registering SecretService provider: dbus: DBUS_SESSION_BUS_ADDRESS not set
2019/06/12 08:49:21 Failed to get the value from the keyring: keyring/dbus: Error connecting to dbus session, not registering SecretService provider: dbus: DBUS_SESSION_BUS_ADDRESS not set
2019/06/12 08:49:21 Failed to decrypt the testing data using the password from KeyChain/Keyring: crypto/aes: invalid key size 0
2019/06/12 08:49:40 Failed to store the value to the keyring: keyring/dbus: Error connecting to dbus session, not registering SecretService provider: dbus: DBUS_SESSION_BUS_ADDRESS not set
