Is there any way to impose bandwidth control in the GUI?
Can any settings in the .duplicacy folder be altered directly outside the GUI?
The rate limit is used to set the maximum upload speed (in kilobytes/sec). However, due to compression and deduplication the upload speed shown in the status bar is usually larger than that.
Yes, the GUI settings are saved in .duplicacy/schedule which is just a json file and can be manually edited.
Man I guess I was tired. I didn’t see the field. Thanks!
Very impressed with the product.
