Hi there,
I’m interested in Duplicacy mostly because of how it’s customizable and easy to migrate backups.
Here is what I want to do and I would like to know the best way to do it safely:
Let’s say I have a 3To computer drive I want to backup to Gdrive. This computer is not connected to a very fast internet connexion, so I have decided to make the initial backup to a local Synology Nas and then connect this Nas to a faster internet provider and upload from there to Gdrive.
I don’t have enough room on the nas so I have decided to do the initial backup piece by piece. Is this the correct way to do it:
1 - I select the entire 3To repository but I exclude half the folders so I have enough room to backup a first batch to the nas.
2 - I backup the first half to the local nas.
3 - I upload this first batch to Gdrive.
4 - I delete the chunks on the nas to free up space (can I delete everything or do I have to keep some specific files?)
5 - I select the other half of the 3To repository and exclude the first part already backed up and send it to the nas.
6 - I upload this other half to Gdrive in the same folder.
7 - Once the initial backup is done, I change the backup destination on my computer from local nas to Gdrive folder, so it’s now linked to the cloud.
Is this a correct way to do it? Or is it impossible because of folder names and other stuff I didn’t think of? Any tips?
Thanks a lot for your help!
