[BUG] When adding minios:// Storage https:// prefix is needed and also not needed
Add a storage; Storage configuration S3; Service Provider: minio (over HTTPS)
add a minios storage without having to work around the errors.
When entering the Endpoint:
  1. to be able to select the bucket and the folder via the buttons the Endpoint has the be entered with https:// prefix - otherwise I get the following error:
"Failed to list the buckets: BadRequest: Bad Request status code: 400, request id: , host id: "
  1. when trying to add the storage with the https:// prefix in Endpoint I get the following error:
Failed to check the storage at minios://@https://:9000/1/1: InvalidParameter: 1 validation error(s) found. [region and ip removed]
To work around this, I must remove the https:// prefix from Endoint address and then click continue.
I fixed this in my code base and should be included in this week’s release.
This is now fixed. See the details in: Duplicacy Web Edition 1.3.0 is available.
Thanks, I can confirm that it is fixed now!
