Can anyone help me please?
I’m using the web version of Duplicacy and it is on version 1.8.3.
I have created a job schedule to copy from source to google drive and it failed. It says “ERROR CHUNK_DECRYPT An RSA private key is required to decrypt the chunk
An RSA private key is required to decrypt the chunk”.
So what I did was:
  1. Generate RSA public and private key on PKCS#1 format.
  2. I created a local disk storage(for example, Z_Media), add password, tick RSA encryption then add the public.pem key that was generated on step 1.
  3. On backup, I created a backup, choose the local directory to be backed up(Media folder), and choose the storage that was created on step 2.
  4. Then I click the “play” button to start the backup. Then I run the “Check” job so I can see the stats of it.
  5. I want to copy the already backup folder(Z_Media) to Google Drive.
  6. So I created another storage GD_Media, same password and same RSA public key. This time, I also tick the “Copy compatible” and choose “Z_Media”.
  7. Then I run copy job on the schedule tab but the error is:
“Running copy command from /cache/localhost/all
Options: [-log copy -from Z_Media -to GD_Media]
2026-06-19 16:35:07.383 INFO STORAGE_SET Source storage set to /data_backup/Media
2026-06-19 16:35:07.402 INFO STORAGE_SET Destination storage set to gcd://Duplicacy/Media
2026-06-19 16:35:18.894 INFO BACKUP_KEY RSA encryption is enabled for the destination
2026-06-19 16:35:19.851 INFO SNAPSHOT_COPY Chunks to copy: 2238, to skip: 0, total: 2238
2026-06-19 16:35:19.907 ERROR CHUNK_DECRYPT An RSA private key is required to decrypt the chunk
How to solve this? I have the private key but where should I put it?
For clarification:
Media folder - local directory to be backup
Z_Media - local directory that contains the backup of Media folder.
GD_Media - Google Drive storage that should contains the same contents on the Z_Media because of the “Copy” job.
The copy job still has to read/decrypt chunks from the source storage, so with RSA enabled the public key alone is not enough. Add the matching private key to the source storage/config first, then test a tiny restore or check from Z_Media before running the copy again. Also make sure GD_Media is really copy-compatible with Z_Media and uses the same storage password/settings; otherwise Duplicacy may have to re-encrypt instead of just copying chunks.
One extra thing to check: the private key needs to be available to the Web UI process that is doing the copy, not just stored somewhere on your PC. I would add/import it on the source storage side first, then run a small restore or check against Z_Media before starting the full Google Drive copy. Also keep an offline copy of that private key; without it the RSA-encrypted chunks are not recoverable.
