Can not handle 302 redirects correctly when using webdav
duplicacy init -encrypt -storage-name alist share-bowen webdav://duplicacy@xx.xx/dav/duplicacy
Enter the WebDAV password:*****
Enter storage password for webdav://duplicacy@xx.xx/dav/duplicacy:********
URL request 'GET config' returned status code 302
The application should use the redirected URL.
The application does not handle 302 redirects correctly.
I met the same error with webdav. Is there any plan to support 302 redirect?
> duplicacy add -e webdav mywork webdav://*@*
Enter storage password for webdav://*@*:**********
Re-enter storage password:**********
/home/*/Work will be backed up to webdav://*@* with id mywork
> duplicacy backup -stats -storage webdav -t init
Storage set to webdav://*@*
Enter storage password:**********
I met the same error with adding webdav.prompting 302 error and “Failed to download the configuration file from the storage: Maximum backoff reached”!
There seems to be no progress, I have to give up duplicacy.
This is the issue: the developer has explicitly opted to disable WebDAV’s 302 redirection, though the rationale behind this remains unclear.
Duplicacy likely disables redirect following because WebDAV uses state-changing methods, and “302 Found” is historically unsafe for automatic replay since clients may change the request method on redirect.
RFC 9110 explicitly warns that for 301 and 302 a user agent may change the method, and says to use 307 or 308 when method preservation is required.
@gchen to confirn
