I tried twice to do duplicacy check -chunks -threads 4 with Dropbox as my backend, but this does not seem to be working. Both times, after a few hundred thousand chunks, duplicacy gives up. When it fails in this way, the verified_chunks file is not written, so i cannot pick up where I left off and am not making any progress towards my goal of verifying all chunks.
I don’t know anything about Golang but the output suggests to me there is a concurrency bug in Duplicacy. error.txt (32.7 KB)
Here is a snippet:
Verified chunk 06a1e399f234f68a1c05ad86178e4697b96c70472cd89024ef5bacae12d57d66 (591801/3267815), 21.96MB/s 7 days 01:14:03 18.1%
Verified chunk 01f59a3a8977f93a2c807bf304f22f6b06abff7b3956d841f002300574302b14 (591802/3267815), 21.96MB/s 7 days 01:14:04 18.1%
Verified chunk 7c2f487864da3fab921d9c70c98fb041c8ef08de3e8a5ce87f198d14a03e6119 (591803/3267815), 21.96MB/s 7 days 01:14:03 18.1%
Failed to download the chunk 117a57f2a70fed03aa255fb24fb2c5155730893bc4020a819455794732a0e58d: read tcp [2600:1700:8fd0:608f::d4c]:
55026->[2620:100:6017:14::a27d:20e]:443: read: connection reset by peer
Verified chunk 6543a5aca7ca8efea79ec518f29256aa96f33effb22b5a8ee01739c1fcf98831 (591804/3267815), 21.96MB/s 7 days 01:14:03 18.1%
Verified chunk 5e2daf8a553ab70f06faad1c79a2b134b5d9d3581d2c464119edc183f27845d7 (591805/3267815), 21.96MB/s 7 days 01:14:03 18.1%
Verified chunk 977705a6df268f37dfca6d7e7e3b7859df58d5f3af0d541065e05747712f3ab1 (591806/3267815), 21.96MB/s 7 days 01:14:03 18.1%
Verified chunk 6ab616e0c35a1bea5fb01109988d34690325e2c0bc1f8950b6f094437614f882 (591807/3267815), 21.96MB/s 7 days 01:14:03 18.1%
Verified chunk 313c308327c2f7169c7d37fc1a2217840cbde5a23cfe84d1b7cbe7d765725bc1 (591808/3267815), 21.96MB/s 7 days 01:14:03 18.1%
fatal error: concurrent map read and map write
Verified chunk f35c7e323da808cca13e97dcc1f6965cfb8a68fab240e31bb557f72a3ad49462 (591809/3267815), 21.96MB/s 7 days 01:14:03 18.1%
goroutine 80 [running]:
runtime.throw(0x136de59, 0x21)
/usr/local/go/src/runtime/panic.go:1117 +0x72 fp=0xc001922da0 sp=0xc001922d70 pc=0x437f32
runtime.mapaccess2(0x1195a20, 0xc034b38000, 0xc002598320, 0xc002598320, 0xc0474f1f38)
/usr/local/go/src/runtime/map.go:469 +0x255 fp=0xc001922de0 sp=0xc001922da0 pc=0x40f7f5
reflect.mapaccess(0x1195a20, 0xc034b38000, 0xc002598320, 0x135e83c)
/usr/local/go/src/runtime/map.go:1318 +0x3f fp=0xc001922e18 sp=0xc001922de0 pc=0x46b3bf
reflect.Value.MapIndex(0x1195a20, 0xc034b38000, 0x15, 0x1125680, 0xc002598320, 0x98, 0x1124b80, 0xc005ded6f8, 0x86)
/usr/local/go/src/reflect/value.go:1189 +0x16e fp=0xc001922e90 sp=0xc001922e18 pc=0x4a710e
encoding/json.mapEncoder.encode(0x139f6a8, 0xc005470000, 0x1195a20, 0xc034b38000, 0x15, 0x1190100)
/usr/local/go/src/encoding/json/encode.go:813 +0x317 fp=0xc001923038 sp=0xc001922e90 pc=0x527557
encoding/json.mapEncoder.encode-fm(0xc005470000, 0x1195a20, 0xc034b38000, 0x15, 0x1c40100)
/usr/local/go/src/encoding/json/encode.go:779 +0x6d fp=0xc001923078 sp=0xc001923038 pc=0x53392d
encoding/json.(*encodeState).reflectValue(0xc005470000, 0x1195a20, 0xc034b38000, 0x15, 0xc001920100)
/usr/local/go/src/encoding/json/encode.go:360 +0x82 fp=0xc0019230b0 sp=0xc001923078 pc=0x524662
encoding/json.(*encodeState).marshal(0xc005470000, 0x1195a20, 0xc034b38000, 0x100, 0x0, 0x0)
/usr/local/go/src/encoding/json/encode.go:332 +0xf9 fp=0xc001923110 sp=0xc0019230b0 pc=0x524259
encoding/json.Marshal(0x1195a20, 0xc034b38000, 0xc004636024, 0x180, 0xca, 0x0, 0x5d)
/usr/local/go/src/encoding/json/encode.go:161 +0x52 fp=0xc001923188 sp=0xc001923110 pc=0x5236d2
github.com/gilbertchen/duplicacy/src.(*SnapshotManager).CheckSnapshots.func2()
/Users/gchen/zincbox/duplicacy/src/duplicacy_snapshotmanager.go:1024 +0x9e fp=0xc001923248 sp=0xc001923188 pc=0x104dc7e
/Users/gchen/zincbox/duplicacy/src/duplicacy_log.go:229 +0x7a fp=0xc0019232b8 sp=0xc001923248 pc=0x10075da
runtime.call16(0x0, 0x139fc80, 0x0, 0x0)
/usr/local/go/src/runtime/asm_amd64.s:550 +0x3e fp=0xc0019232d8 sp=0xc0019232b8 pc=0x47035e
runtime.reflectcallSave(0xc001923410, 0x139fc80, 0x0, 0x0)
/usr/local/go/src/runtime/panic.go:877 +0x58 fp=0xc001923308 sp=0xc0019232d8 pc=0x4374f8
runtime.runOpenDeferFrame(0xc000375980, 0xc01d21e410, 0x0)
/usr/local/go/src/runtime/panic.go:851 +0x62d fp=0xc001923390 sp=0xc001923308 pc=0x4371cd
panic(0x12330c0, 0xc0022eb380)
/usr/local/go/src/runtime/panic.go:965 +0x1b9 fp=0xc001923458 sp=0xc001923390 pc=0x437779
github.com/gilbertchen/duplicacy/src.logf(0x2, 0x1353537, 0xe, 0x1370cd6, 0x23, 0xc001923970, 0x2, 0x2)
/Users/gchen/zincbox/duplicacy/src/duplicacy_log.go:180 +0x93d fp=0xc0019235e8 sp=0xc001923458 pc=0x100725d
github.com/gilbertchen/duplicacy/src.LOG_WERROR(0xc005ed4900, 0x1353537, 0xe, 0x1370cd6, 0x23, 0xc001923970, 0x2, 0x2)
/Users/gchen/zincbox/duplicacy/src/duplicacy_log.go:114 +0xe8 fp=0xc001923638 sp=0xc0019235e8 pc=0x1006908
github.com/gilbertchen/duplicacy/src.(*ChunkOperator).DownloadChunk(0xc0002a03c0, 0x0, 0x0, 0xc005ed4900, 0x40, 0xc019fc4440, 0x20,
0x907bc, 0x0, 0x0, ...)
/Users/gchen/zincbox/duplicacy/src/duplicacy_chunkoperator.go:415 +0x4ea fp=0xc001923c18 sp=0xc001923638 pc=0xfd722a
github.com/gilbertchen/duplicacy/src.(*ChunkOperator).Run(0xc0002a03c0, 0x0, 0x0, 0xc005ed4900, 0x40, 0xc019fc4440, 0x20, 0x907bc,
0x0, 0x0, ...)
/Users/gchen/zincbox/duplicacy/src/duplicacy_chunkoperator.go:184 +0x1665 fp=0xc001923e70 sp=0xc001923c18 pc=0xfd6ce5
github.com/gilbertchen/duplicacy/src.CreateChunkOperator.func1(0xc0002a03c0, 0x0)
/Users/gchen/zincbox/duplicacy/src/duplicacy_chunkoperator.go:92 +0xde fp=0xc001923fd0 sp=0xc001923e70 pc=0x104b61e
runtime.goexit()
/usr/local/go/src/runtime/asm_amd64.s:1371 +0x1 fp=0xc001923fd8 sp=0xc001923fd0 pc=0x471c81
created by github.com/gilbertchen/duplicacy/src.CreateChunkOperator
/Users/gchen/zincbox/duplicacy/src/duplicacy_chunkoperator.go:87 +0x1ba
For now I’ll try using one thread and see if that works, but this is quite painful because it’ll take weeks to run.
doesn’t retry on errors like that.
