Hello
I just set up an unraid NAS, moved over from Synology. I have Duplicacy up and running. This afternoon I severely messed up my immich install, and need to restore my nas to its previous state. When I try to restore the appdata from duplicicay, it fails with the following message:
Failed to change uid or gid: lchown /userdata/appdata/Backups/Bills PC/Bills PC2025-10-25T090617.vbk: operation not permitted
Exit code: 100
Here is the log:
2025-11-14 17:19:44.500 INFO REPOSITORY_SET Repository set to /userdata/appdata
2025-11-14 17:19:44.500 INFO STORAGE_SET Storage set to sftp://william@100.70.227.23/Unraid
2025-11-14 17:19:44.677 INFO SNAPSHOT_FILTER Loaded 0 include/exclude pattern(s)
2025-11-14 17:19:44.685 INFO RESTORE_INPLACE Forcing in-place mode with a non-default preference path
2025-11-14 17:19:44.685 INFO RESTORE_INDEXING Indexing /userdata/appdata
2025-11-14 17:19:44.685 INFO SNAPSHOT_FILTER Parsing filter file /cache/localhost/restore/.duplicacy/filters
2025-11-14 17:19:44.686 INFO SNAPSHOT_FILTER Loaded 0 include/exclude pattern(s)
2025-11-14 17:19:54.287 WARN LIST_FAILURE Failed to list subdirectory PostgreSQL_Immich/: open /userdata/appdata/PostgreSQL_Immich: permission denied
2025-11-14 17:21:04.623 WARN LIST_FAILURE Failed to list subdirectory postgresql_immich/: open /userdata/appdata/postgresql_immich: permission denied
2025-11-14 17:21:04.624 INFO RESTORE_START Restoring /userdata/appdata to revision 17
2025-11-14 17:21:05.048 ERROR RESTORE_CHOWN Failed to change uid or gid: lchown /userdata/appdata/Backups/Bills PC/Bills PC2025-10-25T090617.vbk: operation not permitted
I am totally at a loss- have never used a command line, so I have been trying to do this only using the GUI.
Can someone have mercy on a total
newb and help me get this fixed?
