I’ve been using
for a long time, but as restores from remote and large repositories is pretty slow, I have been playing with the idea to backup local with short retention and copy to remote for longterm storage.
So, I set up an SFTP storage on a local fileserver and set up completely separate backups. That worked as expected. Check, prune, all fine and dandy. This ran for a week or two without issues.
As a next step, I wanted to start playing with backup-and-copy, so I deleted the storage from
, completely wiped all files on the storage and reconfigured it as copy-compatible with my existing primary storage on B2 and started a fresh backup.
Large job, takes a good while, but ran fine and completed succesfully. I then ran a check… and apparently every single chunk it’s expecting to be there, is missing.
When I go to inspect the files on the storage, there are plenty of chunks, with appropriate dates (so no leftovers from the previous incarnation)… but I tried about a dozen chunk IDs, and none of them exist.
I ran a new backup and another check, and for that new revision all chunks are also missing…
So, I’m a little confused at what’s happening. Did I need to do more than just wipe the data on the storage? Surely all local configuration and caches should be gone by deleting the storage from
