I created, and recreated public and private PEM keys using the following commands:
openssl genrsa -aes256 -out private.pem -traditional 2048
In the restore section I have:
I’ve tried for “passphrase”:
- The passphrase I used to create the pem file
- The first passphrase you make after installing duplicacy
- The storage passphrase
All give me the same error.
Failed to parse the private key in /repo/private.pem: asn1: syntax error: sequence truncated
Exit code: 100
