I’m using the Web GUI 0.2.10 Beta on Linux.
My local backup jobs to disk are running fine and the subsequent copy to B2 Backblaze.
The only problem I have is that the check command no longer works and gives and “Invalid options” error. Do I have to many chunks for the check to work?
2019-05-07 19:00:09.897 INFO BACKUP_STATS Files: 121316 total, 622,963M bytes; 0 new, 0 bytes
2019-05-07 19:00:09.897 INFO BACKUP_STATS File chunks: 127337 total, 623,185M bytes; 0 new, 0 bytes, 0 bytes uploaded
2019-05-07 19:00:09.897 INFO BACKUP_STATS Metadata chunks: 8 total, 40,683K bytes; 0 new, 0 bytes, 0 bytes uploaded!
All chunks: 127345 total, 623,225M bytes; 0 new, 0 bytes, 0 bytes uploaded
2019-05-07 19:00:09.897 INFO BACKUP_STATS Total running time: 00:00:08
Please help!
Cheers pdaemon
 box under the post. That of course may include your own post
