I’ve read somewhere in this forum that check continues from where it last finished. I took that to mean it doesn’t do the check across everything - only things that have changed since last check. Is that correct? Also…
If i set “maximum run time” does it continue from where it stopped according to that setting?
If the job is aborted by the user, will it resume from where it was aborted? Or does it need to start over?
If some error or system problem occurs, where does it start/resume from?
Cheers
