Every day I do a backup and check:
Every day the check fails with “Missing chunks”. I then delete from Backblaze the revision containing missing chunks. I backup again, and same thing, the check fails with “Missing chunks”.
The logs of the last failed check:
Running check command from /home/lcswillems/.duplicacy-web/repositories/localhost/all
Options: [-log check -storage Backblaze -fossils -resurrect -persist -a -tabular]
2025-02-24 23:44:52.085 INFO STORAGE_SET Storage set to b2://lucas-willems-backup-duplicacy
2025-02-24 23:44:52.638 INFO BACKBLAZE_URL Download URL is: https://f004.backblazeb2.com
2025-02-24 23:44:54.333 INFO SNAPSHOT_CHECK Listing all chunks
2025-02-24 23:45:35.028 INFO SNAPSHOT_CHECK 1 snapshots and 28 revisions
2025-02-24 23:45:35.033 INFO SNAPSHOT_CHECK Total chunk size is 304,158M in 108257 chunks
2025-02-24 23:45:35.112 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 1 exist
2025-02-24 23:45:35.179 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 43 exist
2025-02-24 23:45:35.245 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 149 exist
2025-02-24 23:45:35.302 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 183 exist
2025-02-24 23:45:35.389 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 217 exist
2025-02-24 23:45:35.479 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 238 exist
2025-02-24 23:45:35.548 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 270 exist
2025-02-24 23:45:35.641 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 305 exist
2025-02-24 23:45:35.754 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 340 exist
2025-02-24 23:45:35.882 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 371 exist
2025-02-24 23:45:36.002 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 405 exist
2025-02-24 23:45:36.137 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 427 exist
2025-02-24 23:45:36.297 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 459 exist
2025-02-24 23:45:36.426 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 482 exist
2025-02-24 23:45:36.573 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 483 exist
2025-02-24 23:45:36.744 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 511 exist
2025-02-24 23:45:36.909 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 521 exist
2025-02-24 23:45:37.090 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 529 exist
2025-02-24 23:45:37.296 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 536 exist
2025-02-24 23:45:37.484 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 540 exist
2025-02-24 23:45:37.664 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 541 exist
2025-02-24 23:45:37.854 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 542 exist
2025-02-24 23:45:38.038 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 543 exist
2025-02-24 23:45:38.229 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 544 exist
2025-02-24 23:45:38.435 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 545 exist
2025-02-24 23:45:38.623 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 546 exist
2025-02-24 23:45:38.816 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 547 exist
2025-02-24 23:45:39.625 WARN SNAPSHOT_VALIDATE Chunk 598d78045b88289e8f4820a9a90c0eddd3e379c0bc6e3b582449e2da90302385 referenced by snapshot Data at revision 548 does not exist
2025-02-24 23:45:39.941 WARN SNAPSHOT_VALIDATE Chunk 47f78e9f0a7755cccc5faf6b3554550d2fffb1791801ffe9cff5d19c2fd9ab51 referenced by snapshot Data at revision 548 does not exist
2025-02-24 23:45:40.247 WARN SNAPSHOT_VALIDATE Chunk aff4510da0e84ab67a6e9a2dac32bc476733a9bd1338fe7788c05f304ce43c8a referenced by snapshot Data at revision 548 does not exist
2025-02-24 23:45:40.554 WARN SNAPSHOT_VALIDATE Chunk bb13dfadcbb96e41cc3dff94089001b616bbed4c55db407dfb9b288dbcd28f70 referenced by snapshot Data at revision 548 does not exist
2025-02-24 23:45:40.561 WARN SNAPSHOT_CHECK Some chunks referenced by snapshot Data at revision 548 are missing
2025-02-24 23:45:40.561 ERROR SNAPSHOT_CHECK Some chunks referenced by some snapshots do not exist in the storage
Any idea why I’m getting those errors?
