After collecting diagnostic info related to configuring https on a QNAP, I inadvertently had two duplicacy_web processes running due to a known bug in stopping the QNAP qpkg. As a result, two duplicate backup/prune/copy/check schedules were run in parallel.
The backup, copy, and check jobs ran without warnings or errors. One prune job failed:
2021-01-17 00:32:16.255 WARN CHUNK_DELETE Failed to remove the file chunks/b7/e3146349276347704dc5ce02883cd72d5df059085d53647fb52aab2205433b.fsl: URL request 'https://api000.backblazeb2.com/b2api/v1/b2_delete_file_version' returned 400 File not present: chunks/b7/e3146349276347704dc5ce02883cd72d5df059085d53647fb52aab2205433b 4_zb3083158c24667c375580610_f113621029019f94b_d20210115_m092030_c000_v0001076_t0014
2021-01-17 00:32:17.072 ERROR FOSSIL_COLLECT Failed to read the fossil collection file fossils/47: open /share/CACHEDEV1_DATA/.qpkg/Duplicacy/.duplicacy-web/repositories/localhost/all/.duplicacy/cache/Backblaze-B2/fossils/47: no such file or directory
All other prune jobs logged WARN CHUNK_FOSSILIZE Chunk ... is already a fossil warnings.
Copy jobs showed discrepancies between the number of chunks expected to copy and actually copied, e.g.:
2021-01-17 02:10:07.207 INFO SNAPSHOT_COPY Chunks to copy: 5, to skip: 111, total: 116
2021-01-17 02:10:07.299 INFO COPY_PROGRESS Skipped chunk 5744a3f6248a28123d20bb80e644fb1f6e7c302a0f1a46297a9df354b9e5951d (1/5) 80KB/s 00:00:00 20.0%
2021-01-17 02:10:08.531 INFO COPY_PROGRESS Copied chunk 1d5c621448a41476e46abb173f1fc1fc934d537076b58a5f3398cfe133d9184d (2/5) 4.02MB/s 00:00:01 40.0%
2021-01-17 02:10:09.350 INFO COPY_PROGRESS Copied chunk 4c08280f30cb685816c6fe1c490becf3b4d52567f81c5a39ee55418f493a0a97 (3/5) 3.51MB/s 00:00:01 60.0%
2021-01-17 02:10:10.038 INFO COPY_PROGRESS Copied chunk 86c98bb2296c9ea52765883dbdd072f1f5803db9f9a0864dfe5d4abb217226b5 (4/5) 2.66MB/s 00:00:00 80.0%
2021-01-17 02:10:10.060 INFO COPY_PROGRESS Skipped chunk e8877b3153eb26dbeadb10c6276849bb46b3b6468491991019ed8a7ca1638e88 (5/5) 2.76MB/s 00:00:00 100.0%
2021-01-17 02:10:10.151 INFO SNAPSHOT_COPY Copied 3 new chunks and skipped 113 existing chunks
2021-01-17 02:10:10.639 INFO SNAPSHOT_COPY Copied snapshot Duplicacy-config at revision 93
Subsequent check jobs on both the local and B2 storages were successful, as was a check -chunks on the local storage.
Should I do anything else to check the integrity of the storages? Could this have corrupted the web UI configuration/cache? If so, how can I check/recover?
