Hi. I have backed up roughly 10 directories that are all part of the same parent directory. I’m thinking it would be much simpler to just backup the parent folder as one job rather than 10. If I delete all the current subfolder backup jobs/id’s from Duplicacy, and add the parent backup as a new job/id, will all of my data have to be uploaded as fresh? Any other considerations?
If this is not a problem, would it be better to add the parent directory job, back it up, and then delete the subs? Or would it make better sense to delete the sub jobs first?
I use the GUI btw.
Thank you!
