Hi all,
I’ve been a duplicacy web user for a while now and have a basic understanding of how to use the CLI but I can not figure out how to solve this problem.
What I want to do is combine two existing storages into one new storage. As follows:
Current Setup
- Storage 1 (no e-coding; encrypted with password x; stored on Server A): backup of computers 1 & 2
- Storage 2 (e-coding; encrypted with password y; stored on Server B): backup of computer 3 & computer 4
Setup I Want
- Storage 3 (RSA encrypted; with e-coding; stored on Server A): containing all current snapshots in Storages 1 & 2 above. I want to be able to backup computers 1 & 2 directly to this storage and periodically Copy backups contained in Storage 2 to this storage
- Storage 1: will be deleted post migration of backups to Storage 3.
To do this I believe that I would need to make Storage 3 copy compatible with both Storage 1 and Storage 2 and then simply run a copy operation from both of the current storages into the new one and it should be job done. The only problem is I can’t work out how to do this.
I should also mention that I have access to both Server A and B and they are both geographically in different locations. I can run local copy operations on either server and would like to minimise transfers between servers (although that will obviously need to happen to move the contents of Storage 2 to Storage 3).
If someone could give me some pointers in the right direction that would be great.
