Hi Guys,
I’ve got a question about copy command.
I’ve got my local repository that I’m periodically copy-ing to the remote GDrive.
Repository is quite large (~5TB), and it took couple of days to transfer initially. Neverthenless, now, copy takes much less time, since this repositiory doesn’t change very often, and incremental changes are much smaller.
I’ve wanted to check integrity of both of these repositiories, so I’ve ran check command on both, and it looks like my local one is fine.
However, GDrive respository is missing something:
Chunk 08d10c13889120e215dddb4ce47be51384432e13d8be42bd54090190c0d28d53 can't be found
And indeed, I’ve checked GDrive manually, and there isn’t any 08 direcotry there, so this chunk is actually missing.
However, when I’m running copy command, it works flawlessly, and doesn’t throw any error (I guess that it thinks that older snapshots are fine, so it’s processing only new ones).
I’ve got 2 questions:
- What might have caused this chunk gone missing? I haven’t deleted these chunks on GDrive on my own, so is it possible that duplicacy haven’t copied it in the first place?
- Can I somehow repair this situation, besides manually checking which chunks are missing from
copycommand and copying them one by one?
