Restoring a repository using a Duplicacy preference directory located elsewhere.
Duplicacy should restore to a repository without creating an empty .duplicacy directory.
Duplicacy creates what seems to be an unnecessary empty .duplicacy directory in a repository when restoring using a Duplicacy preference directory located elsewhere.
Possible solution
The code line in question is located at:
If this is not serving a purpose, may it be removed?
Thank you to all for your work on this project!
