Cron job issue
I’m working on automating the backup/copy process and am stuck on a problem that only arises when I attempt to kick off a copy job via the scheduler. In this case, the job is to start at system reboot.
The script works fine when I execute it from my session and I can manually start the cron job without issue. However, on an actual system reboot it fails.
Command:
duplicacy copy -from default -to wasabi >>$LOGFILE 2>&1
Error Message:
Source storage set to /bkup2/duplicacy
Destination storage set to s3://us-east-1@s3.wasabisys.com/duplicacy-prod
Failed to download the configuration file from the storage: RequestError: send request failed
caused by: Head https://duplicacy-prod.s3.wasabisys.com/config: dial tcp: lookup duplicacy-prod.s3.wasabisys.com on [::1]:53: read udp [::1]:46355->[::1]:53: read: connection refused
Looks like something is amiss at the network layer. Any guidance on what may be happening?
I guess it is because the network layer wasn’t ready when the script was run. Adding some delay may help (the GUI version does exactly this).
Bingo! Thank you.
