Deleting storages and backups - still remembered?
I am new to Duplicacy, having moved over from Duplicati recently. After testing out different storage options and naming schemas, I have finally settled on my preferred setup. After removing a bunch of backup profiles and a couple of storages I now find myself with a bit of a mess.
In the WebUI dashboard I still see revisions for backups and storages that have been deleted, and when I create a new storage using an old name it picks up metadata that is no longer valid. I’ve looked through the preferences files in the local config folder and can clearly see references to stuff that has been deleted.
Is there an easy way for me to make Duplicacy completely forget everything that is deleted (storages and backups)?
When you delete a storage, the web GUI doesn’t remove backups and jobs that reference the deleted storage automatically. This allows you to create a new one with the same storage name as a way to 'edit` a storage.
