Does Duplicacy support backing up S3 storage to S3 storage
I tried googling this and using the form search for a bit but couldn’t really find anything on this topic outside of local backups to S3 storage. It is possible my search terms were bad.
I was just wondering if it Duplicacy is able to backup object from an S3 bucket to another S3 bucket. I have a web server that directly uses an S3 bucket for storage and wanted to use the CLI version to backup to a separate S3 service. It is possible this is outside the scope of Duplicacy but I just wanted to know if anyone has any experience with this.
I was able to successfully configure Duplicacy on my Desktop and NAS to backup to the NAS and an S3 bucket and I’m very impressed with it’s speed and performance.
You can use Rclone with mount command to create a point to your repository (source) in the first S3 bucket, configure Duplicacy to use this point as a repository, and back it up normally to the storage configured in the second S3 bucket.
I use this to backup a gdrive to a S3 bucket and it works perfectly.
Thanks for the advice, I didn’t know you could do something like that
dos it works well for you ?
i have tried te same scenario on pi4 8gb and it keeps saying incomplete snapshots
I don’t think I tried, ended up not deleting the S3 backup
