I don’t have a lot of data changing, eventually it will mainly be photo backups.
Definitely remove -exclusive flag.
Also remove -exhaustive flag. There is no reason to use it every time. It just wastes time.
Ok, I only put them there because the 11GB fossil collection wasn’t being removed with just the standard prune.
But is a weekly check followed straight away with a prune ok?
More importantly, remove -exclusive from prune. Your backups may still be running when you start doing this prune, and that would be a bad thing.
I’d run check after prune - when prune deletes a bunch of stuff, you will see the end result in stats, otherwise your stats will always be wrong.
