I have set up a storage with RSA encryption with CLI. I want to now backup more files there on another computer using the Web-GUI. The add-new-storage process does not ask anything about RSA keys and the backup just started “working”. I just want to make sure does it use the same public key to encrypt the files with RSA? Or do I need to give some extra parameters to it?
The RSA public key is stored in the config file, so you don’t need to pass in extra parameters. It is enabled by default.
Thanks. For sake of user friendliness, the Web GUI could make a mentioning of the “RSA key found”.
There should be a line in the backup log file that says RSA encryption is enabled.
Yes, but for sake of usability the Web GUI itself could tell the same. RSA encryption is enabled is better than RSA key found.
