I add my Dropbox token, but I see no directories to select. Just an empty box where the directory list should be.
Any ideas?
Any ideas?
You can either create the directory manually in Dropbox (under Apps/Duplicacy), or type in a directory name to let Duplicacy create one for you.
RESOLVED Thanks again
Feel free to mark the comment that resolved the issue as “solution” by clicking the ”
Solution” under said comment: that way the answer will appear next to your question and will make it easier for future readers to find it
