Backups/pruning etc started failing today, with the error below. Looks like the dropbox access token needs refreshed, but I can’t work out how to do that through the WebUI - I don’t seem to be able to edit settings for the existing Dropbox storage, only add new storage. Would appreciate a pointer as to how to update the existing storage with a new access token!
Thanks in advance.
Error:
Running backup command from /cache/localhost/0 to back up /source
Options: [-log backup -storage Dropbox -threads 1 -stats]
2024-01-01 04:00:01.437 INFO REPOSITORY_SET Repository set to /source
2024-01-01 04:00:01.437 INFO STORAGE_SET Storage set to dropbox://Backups
2024-01-01 04:00:01.439 ERROR STORAGE_CREATE Failed to load the dropbox storage: Can’t create storage directory: failed to refresh the access token: Post “https://duplicacy.com/dropbox_refresh”: dial tcp: lookup duplicacy.com on 127.0.0.11:53: server misbehaving
