Duplicacy CLI 3.2.3 release
The CLI version 3.2.3 has been released: Release Duplicacy Command Line Version 3.2.3 · gilbertchen/duplicacy · GitHub
3.2.3 change:
3.2.2 change:
  • Save storj credentials in keychain/keyring after a storj storage has been successfully created: 7bfc0e7
3.2.1 changes:
  • Removed a false check that caused an initialization error with zstd-enabled storages: #653 (thanks to @gorbak25)
  • Allow two copy-compatible storages to have different compression levels: 4e9d2c4
  • Skip identical entries when listing chunks: d92b173
  • Upgraded Go version to 1.19.13
3.2.0 changes:
  • Added a Samba backend: 3a81c10
  • Implemented zstd compression: 53b0f3f
  • Added support for custom OneDrive credentials: #632 (thanks to @sevimo123)
  • Added support for SharePoint document libraries to the ODB backend: #633 (thanks to @sevimo123)
  • Fixed a connection leak in the Dropbox backend on some http errors: gilbertchen/go-dropbox#5 (thanks to @northnose)
  • Fixed bugs that caused the B2 and Google Drive backends to fail to download metadata chunks that have been marked as fossils: ff207ba 1f9ad0e
  • Fixed a crash when some backends return with an empty entry path: cdf8f5a
  • Fixed a crash caused by concurrent access to a map during chunk verification: #649 (thanks to @northnose)
  • Fixed a chunk leak when listing files in a revision: 9be475f
This topic was automatically closed 20 days after the last reply. New replies are no longer allowed.
